Im having a few problems guys, maybe you could help.
My mechanic, who is very knowledgeable, tells me that I have a severe problem with my brake system. My problem is I don't have the money that he wants (~1200) to fix it. I know he said the brakes line was broken in places and it would be around 400 to get the all the lines replaced. He also said something about the Master Brake Cylinder is about to go out and has no clue to how it is still working (which is understandable since right now if you apply more than just a little bit of pressure on the brakes they lock) and the other issue is the driver rear brake doesn't work, and the front passenger does most of the work. When I lock the brakes you can tell only 1 brake is locking. I was just hoping that I can just sit down one weekend and just fix this by myself and not have to pay a mechanic. Also, it is leaking lots of oil and I think he said something about the front seal going bad. He priced it around 1500 to fix it. I asked for a list for everything that was wrong with the car and it was priced at $9300, not including body work it needs. For $9300 + body (~4500) I could easily go get a 03 Tundra or 02 Acura CL Type-S.
Any ideas?
Any ideas?
