brake pedal going to floor when running???
AJ'S 88NA
2,419
Florida
suprra_girl said:
When the car is off the pedal is awesome, right up and no air.
As soon as it start the car the pedal goes to the floor.
Anyone had this? How do i fix, i really wanna drive my car today :D
but with brakes haha
Never had that problem, but it sounds like a problem with the brake booster. Check your vac lines to it.
If you let the reservoir get real low you may have air in your booster. It will have to be bled.http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=BR&P=6
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Master cylinder?
Booster should have air in it at all times. It is normal when you pump the brakes with the car off to have a hard peal. When you start the car the pedal should go down. That is the booster doing its job. It's just not supposed to go all the way down.:biglaugh:
The reason you get a hard pedal when the car is off is because you are depleting the booster.
Sounds like you have air in the system/not enough fluid. I would keep bleeding it.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
i vote master cylinder/air. When you press the pedal and it slowly sinks to the floor it indicates fluid leaking past the piston in the master cylinder, assuming you have no external leaks
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i bled those lines ALOT and it's all straight fluid, no air at all.
When i pulled off the vacuum line to the booster there was a huge pshhhhhhhh so that suggests it's holding vacuum.
When the car is off i push on the pedal and hold it and the pedal doesn't go down so that suggests no leaks either
There's also no fluid pouring down my booster
And no it doesn't sink without my foot on it, it's just very very soft/easy to push down
Please please please help
I wanna drive my car :(
twinturbozs
131
san francisco
Sounds like you have an internal leak in the MC. I would check for leaks around your calipers first. My guess is to replace the MC since its relatively cheap.
suprra_girl
7M POWAH! ;)
www.supra.co.nz
lilazni3uoy said:
you need to make sure you have that valve, that goes from the brake booster, to the intake manifold, !! or else the pedal will go to the floor even tho it's bled
well i know my lungs don't near count towards engine vacuum lol but i can blow through the valve but not suck through it so i guess it's not leaking
if the booster doesn't fix it i will replace that next anyhow :)
thanks ;)
cuel
1,536
Baytown, Texas
suprra_girl said:
thanks for the suggestion but i already replaced the master cylinder and i had absolutely no change whatsoever.
I do find it suspicious that i have funny fluidy squishy sounds in my booster tho
Sounds like the old master cylinder was leaking into the vacuum booster. You might be able to find a used one in the f/s section.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Booster would have been my choice as well. My old room mate blew the booster in his DSM, it would suck brake fluid through it into his intake manifold. Car was running really funny while trying to burn brake fluid along with gasoline.
