So my brake lights are not working, my 3 brake light (wing) works, but the brake lights are not working when i step on the brake. I looked for a switch under the brake pedal and there is nothing there. I checked my 20 amp fuses and they are all fine. Is this a blown lamp failure box? I took it out and took it apart and everything looked real clean and all solder points were fine. I swapped out the bulbs and it is still not working. My turn signals work and my rear tails work when my headlights come on if that helps. It is only when I step on my brake that i am getting nothing. lmk.
