brake coolers (the right way)
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
recently in another post somthing was said about not removing the fog lights unless u planned to do brake coolng ducts well I have seen it done alot of shitty ways but here is a good ay to do it, I'm currently running this on my 90 supra, well its installled i havent been able to test it out yet but i will when i get back home and finish the eng up......Any way this is a set used on the FC RX-7's wich also fit on my Supra, which i have turned the wheels lock to lock and it doesnt hit any thing all you do is plum in 3" flex hose to where your foglights are. Here is a site that sells some, tho the ones I have are 5 lug lol. http://www.rotorsportsracing.com/images/awrfrontbrakeducts.jpg
Spiv
hooligan
Orlando, Fl
I think I'd rather get a front lip that has some shapely ducts in it instead of sacraficing the fog lights. I'd also make sure to try some of the other good solutions to "brake fade" if you havn't already (#1 high temperature fluid, #2 better pads)
