Brake Caliper Comparison
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Lucked out and got a set of 89 calipers, kinda borrowed, took them apart and cleaned, order new OEM rebuild kits, and was taking them to a buddy that powder coats stuff for me. Got to looking at them and they are a little bit different from mine ('91 model).
Gonna physically "try them on" tomorrow, but thought I would ask if pre '91 calipers bolt up to post '91 models.
Any help would be great.
Thanks
Wayne
3rdtimearound
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
toyota sopositly made a casting change that was on all post 08/90 cars, there is no advantage to using one or the other, and they are all interchangable
SPD TRP
Apr 12, 2005
526
Katy Texas
"Tried them on today after work. The castings are a little bit different, but they bolted right up and according to Toyota, the rebuild kits are the same part number.
I powder coated the calipers on my Conquest and they never burned off, just rotate the wheel where I could get a soapy rag on them and they were as red and shiny as when I first did them.
Thanks for the input,
Wayne
3rdtimearound
Supra5MGTE
421
Tampa, FL
I don't like to paint my calipers. I like them to expel heat like they were engineered to do. I'd forget the paint, throw up some SS lines, Duct up some cooling pipes, and get some cross drilled and slotted rotors. and run some Synthetic Valvoline DOT 4 brake fluid. I used to Auto Cross my '89 corvette in the FL summer, so i know how to boil brake fluid. Also had brake fluid boil at 140mph 2x's. Valvoline never did! I swear by that stuff.
