I just completely redid my brakes (rotors, calipers, pads, ss lines, etc.) and I've been bleeding them but I've ran into a problem. Every now and then when the brakes are being pumped by whoever is helping me, fluid will gush out of the reservoir lid (the little part that lets air out). The rear brakes still do not grab at all and the fronts are grabbing some.
The technique I'm using: one man pump and hold the brake pedal down while I open and close the bleed valve. I do it in this order: back-right, back-left, front-right, front-left. I've repeated this cycle countless times and have already completely drained the old fluid out.
Any ideas? Is it that there is still air in the system? The brake system was completely drained of brake fluid when I did the work.
Thanks for the help!
