BOV vaccum line?
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
Whitch vaccume line goes to the BOV.
Purple cir is to the bov, is it the yellow or red arrow?
Where does the vaccum line , yellow arrow, connect to?:icon_conf
Thanks
skim1040
work in progress
Not too sure what you mean about the colors. I could be missing something.
But, you can tap into just about any strong vacuum scource AFTER the throttle body.
Or, if you have an aftermarket vacuum manifold, run a line from there to your BOV.
staticpat
Supra Chair!
Birmingham, AL
I haven't used the stock piping in a while, but it should be red. Closer to the throttle plate = better. The other hose is alot further in the manifold. It's a short length just pull off one side of the hose and blow and see which one it is :D.
crazysupra2JZ
740
Georgia
there's a little tube under the lower intake that the bov get's its vacuum from. so i believe it's the yellow one. it should connect to a little metal tube that should be bolted to the side of the head.
you can see mine...
the red arrow goes to the thermostst housing
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
Another question.
Would it be ok to hook the bov up to one of these 2 ports on the TB?
are they before or after the blade?
CoBHC
Cincinnati
The 2 ports on the TB are different. You want to have the BOV hooked up to the one nearer the end of the car. The other one is for the BVSV and charcoal canister and that's it.
