So about a year ago i bought a 7mgte swap for my NA from craigslist it came with everything harness, all manifolds, intercooler, tranny, everthing and it was all stock looked like it had just been pulled out of a car.
(I know NA swap Q's are supposed to be in the NA section but this is more about the motor i bought for it so im putting it here you can move it if you want)
When i disassembled it i found it had no oil squirters, my first thought was that it was a NA block but it has all the turbo oil lines and 2 knock sensors so i thought maybe a early jdm motor. But later i found it didnt have a r154 it had a the same tranny as my NA.
Right now the motor is rebuilt with a metal head gasket and im looking for a r154 for it, i didnt really care about the oil squirters and it has new gte pistons.
so my question is
where do you think the motor came from and do you think i will run into any problems? i just want to make sure before i continue with the project.
and i was wondering if there is any difference in power handling abilities because i just checked and it has a earlier block without the extra ribs and i didnt know there was a difference untill 2 min. ago
thanks
so my question is
thanks
