LOL BOTH. :aigo: :1zhelp:johnathan1 said:It can be a pain...go at it from underneath. Are you having trouble with the clamp or the hose itself?
If u have access to some large pliers like 20 inchers put them on the hose where the male part of the rad is. Without applying to much pressure as not to damage the outlet or male part of the rad start twisting the the hose around once it starts spinning take a smaller set of pliers and pull on the hose while u twist it back and forth. U might want to cut the hose down to about 6 or 7 inches to make it a little easier to pull off.:icon_biggracingtoyota007 said:i Cant get this stupid hose off any suggestions?
Get a boxed end 12mm wrench and apply pressure on the belt to keep the fan from spinning while u break those bolts loose.:icon_biggracingtoyota007 said:LOL BOTH. :aigo: :1zhelp:
and the fan is being a bitch cant get that off either. lol.
Final answer. Yeah u can as long as your replacing the hose then slit the hose as much as u can going toward the rad then pry that beyaatch off.:icon_razzracingtoyota007 said:im probably going to just cut that shit lolz
WD40 aint gonna get it. Get some PBlaster spray and leave it for about a half hour then try it again. Also try an open end 12mm and go from bolt to bolt even if their acting like they don't want to break.racingtoyota007 said:thats what i tried ^^^ but im just rounding out the nuts. im going to try some wd40
Here on SM we just love happy endings.:icon_bigg BTW did u get both fan and hose or just the hose?racingtoyota007 said:UPDATE: I GOT THE STUPID SHOOT OFF! YES!!!!! yea i was yelling ^_^
