Im having some problems with my assembling my bottom end... im using king bearings, and as soon as i put the thurst washers around the center cap. the crank isn't able to spin.. i also am using royal purp engine assembly lube between bearings for better metal on metal contact... I guess my main question is is the Crank suppose to turn with a slight amount of force.
Thanks
Thanks
