Hello to all who remember me from years ago on another then popular forum and the SOGI list. I recent picked up this MINT 89T (61k, 100% original) and am swapping in my built longblock from my 87T. I'm also going from a SP63 to a Boss Jr. 57 trim to obtain a more street-friendly powerband.
That said, has anyone else run into an issue with the oil return line kinking on a Boss Jr. Turbo? No matter what, there is no way to prevent the line from kinking. I can't rotate the turbo center section any more without the coolant feed fitting touching the heat shield on the manifold. I have a hunch that the return line was designed for the Boss Sr. turbos which have a spacer, therefore the line is too long. However, even if the line were shorter, I'm not sure it would work without kinking. The coolant feed line is also much too long, but at least it will function and should just be a cosmetic issue.
I may go to the setup I had on the SP63 shown in the attachment, which was just a braided SS line on barb fittings with hose clamps. This gets rid of a lot of the rigid fitting length on each end. More ghetto than I would really like and a (small) part of the reason for me going with a "bolt on" kit, but oh well. It seemed to work fine before. Other than that, the turbo looks great and I think will give me exactly what I'm looking for.
I would appreciate any insight.
