Im have a few issues after my rebuild. The 1st one is im not boosting for some reason. I have the turbo hooked up to the wastegate directly with no boost controller. The thing is when i drive it and try to boost in first and second nothing happends. I have a boost controller hooked up and the vac is showing about 22-24 in. That seems a little high since optimal is 18-21. Anyways as soon as boost should build it just stays at zero. I hear a faint blowoff from the bov but not very much. I checked the turbo and wheel spins freely. I tried testing the wastegate and when i put vaccuum into the wastegate nothing happends however when i tried compressed air the rod moved. Does this sound right? Atleast it tells me the rod isnt stuck. I also checked for boost leaks and found nothing. All clamps and couplers are on tight.
On a side not my vac lines are all ascrew. Well not so much but the two vsv nipples are capped, the two nipples on the throttle body are capped, i capped the evap line and running a vented gas cap, i deleted the bvsv since im no longer running egr and everything else is routed stock and/or capped off. So with all that said does anyone know what i should be checking or testing to see what my issue could be?
Btw im running a bolt on sp5857 turbo with an internal wastegate.
