Boost
Junior
143
Ontario, Canada
pressure x volume = flow
flow = power
increasing pressure (boost) will increase flow and therefor power.
Volume is the trapped displacement of the engine, with the level of knowledge you've shown you're at now, don't even begin to consider fucking with that, I'm not meaning to be hard on you, but odds are high that it's beyond you.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
That's not entirely correct.
While there is an increase in flow within the engine due to the positive manifold pressure pushing a little more air into the cylinders, the majority of the power increase comes from the DENSER air charge. It's all about the number of oxygen molecules per volume of air. :)
If you pushed your turbocharger way beyond its efficiency, even if the boost was higher, the air could be so hot that the density is the same, so increasing boost will not necessarily increase power :)
Damn turbos are so complicated.
