hey y'all. im new to the board but i have had a problem with my 90 turbo that bothers me. when im on the gas real hard, th motor will hessitate like im running really lean. feels like the fuel cutoff or something. any help would be appreciated.
sweet, it seems to almost go away after i changed the oil. kinda wierd.doom26464 said:my car seems to do a simalr problem, I was guessing spark plugs and wires as well. When I figure out how to fix it I'll tell u what I did.
not at all. it only looses power, if you want to call it that, for a slpit second, then its back to full power. not dropping boost, no back firing. its just a momentary hesitation in acceleration.lagged said:does it also sound like its rapidly backfireing and you get a massive loss of power? ive been told that could be detonation.
b005t3d said:any other ideas? im still running the ct26 turbo with 550 cfm inj. im using a manual boost controllr and ive only got it set at like 10 psi.
i havent noticed any black smoke although, i am still stock in the intake sensor catagory.shaeff said:eh, do you have a MAF-T or a lexus AFM? if you're still running the stock AFM you're probably flooding the crap out of it. any black smoke? only reason i ask is because you didnt mention that you had any upgrades that would allow more air.
-shaeff
yeah, it a split second then back to full boost. no problems but i might do it several times per gear.cruzinbill said:hey my car is doin this also and it is all stock cept for full hks turboback exhaust it will drive fine thin it i feels like it hesitates misses or hits fuelcut just like u were sayin then as soon as it clears away its like boom everything is fine and ur goin again
