Wednesday, I ran my car hard for the first time since my hg job about 1,000 miles ago on the way home from work. Later on I punched it pulling out of my driveway. My boost gauge shot right past the normal ~6psi and pegged, and the whooshing sound from under the hood made it sound like a major boost leak. There was no loss of power or stuttering, just way too much boost.
My BOV checks out okay and I haven't found any obvious leaks. Ran codes this morning and there's 21 & 52. Don't beat me up over this, but I threw a CEL as soon as I finished the hg and didn't bother checking it until I had this new problem and I've just had a feeling that power has been lacking since I did the hg. Car is a completely stock, '90 turbo with recent JDM swap. Forum searches have pointed fingers in a lot of directions, and I'm not sure where to start, so...
1. In order, what step should I take to diagnose from here?
2. Some of the confusion is a lack of correlation b/w these codes and boost spike. Are they even related?
3. Is it worth my time to do a positive pressure test? SF has a method using a soup can to plug the intake and a tire valve stem to pressurize the system up to ~12 psi.
Sorry for the long post, just wanted to cover everything I know. Thx, Kurt
