boost solinoid
djordan97
199
Kennewick WA
ok here's the deal. I'm not exactly sure I've got my boost solinoid hooked up quite rite. I've got the gm boost solinoid that hpf sells and need to make sure I'm hooking it up correctly. the red line is from my vacuume sorce and the black line goes to my waste gate actuator.
best I can get with my camera
Boostedstr8six
I have better SA than you
Near Columbia, the river
It looks like you plumbed it between the the port on the turbo and the port on the WG actuator. That's correct. From there you could only mix up the ports on the solenoid (barring any wiring issues). I can't tell from your pics and the HPF doesn't have a pic. Are you having any boost control issues? What controls these anyway? Self contained?
djordan97
199
Kennewick WA
I'm using the maft pro to controll it and i'm getting lots of spiking that I can get settled down if I have it hooked up opposite as I have it now. the way I got it hooked up it holds right about 10 psi.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Here's what I found on it...looks like you might have your hooked up backwards.
GM Boost Control Solenoid:
Port 1: Silver plug, by itself on one end.
Port 2: Opposite port, next to port 3
Port 3: Comes with a small filter on it.
I don't believe the solenoid is polarity sensitive.
At rest: Port 1 and 2 allow air to pass. No air can travel from Port 1 to 3, or 2 to 3.
Energized: Port 2 and 3 allow air to pass. No air can pass from 1 to 2 or 1 to 3.
Port 1: To turbocharger, or optionally another line on the compressor side.
Port 2: To wastegate
Port 3: Back into intake, after the MAF.
Port 3 (optional): Just vent to atmosphere, but you should put a filter on it in case of reversal of flow. The GM solenoid comes with a small filter on this port out of the box, so just leave it on if you wish to port to atmosphere.
How this works...
At rest, the solenoid allows the wastegate to see all boost pressure.
When energized, the solenoid blocks pressure from the charge air from reaching the WG, so the WG sees the pressure from the intake or atmosphere. The moment after the solenoid is energized, any air pressure on the wastegate blows back out to the intake/atmosphere, relieving any air pressure on the wastegate.
Downsides: If the solenoid fails in the energized position, your wastegate will NOT open. However, the same general risk is present in a bleed setup. If it somehow fails in the energized position, it will bleed as much air as the stock restrictor will allow, but never absolutely stop pressure from getting to the WG. Failure in the energized state of either setup will cause massive overboost problems.
djordan97
199
Kennewick WA
thank you very much jdub. that does explain alot to me and I think that write up should be included into the maft-pro stuff for dumb people like me.
drjonez
the motor city
www.4cefed.com
why? that solenoid is unsupported. if you had purchased the solenoid that's made for the MAFT pro, you would have received instructions.
