Boost Sensor Wiring
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
I purchased the zeitronic ZR2 with the data logger option, it has the ability to log afr, boost, egt, tps and lambda.
Need to figure out which wire going to the ECU is for the boost sensor so I can splice into it to connect the box. They offer a seperate map sensor to measure the boost levels but Im curious if I could use the stock boost sensor for now?
Halsupramk3
444
Mississippi
the stock boost sensor is a useless POS for any data logging. It is slow to react and inaccurate for relating to any a/f to rpm data.
buy he zeitronic boost sensor 3.5 bar would be enough. i dont know what all that logging unit does but there are some lower cost stand alones out there used that can do alot of that. aem boost sensor appears to be the same. i have both and they are very sensative. my aem ecu showed boost spikes and fluxuations till i upped the boost filter from zero to 6 teeth so it only reads presure every 6 teeth of the cps wheel. now it shows a steady reading. i dont know if your logger has a map filter to keep it from being too sensative.
