boost problem!
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
I am hitting 10psi for boost which is better but at the top of the gear it is dropping to about like 5! and for vaccum i am about 19 is that good?
thesupraman
Smirker
May 15, 2005
129
Frenchtown, NJ
Vacuum sounds right, as for boost...dunno.....is there a gain setting on your profec? If so, try messing with that. I forget which way it goes but if it is too far one way it will spike and then drop, too far the other way and it will surge and vary.
Furball
Yes, I play Halo
Apr 2, 2005
183
Merced, CA
How high are you talking about when you say top of the gear? I have heard that the stock wastegate actuator can cause the boost to drop up high. To combat this shim the wastegate with one or two washers. This will help hold the wastegate open for the last few hundred RPMs.
