So Heidi and I built the $5 boost leak tester (it ended up costing closer to $8 since we used high quality neoprene hose, instead of rubber) and we found a HUGE leak...
The throttle body port to the cam covers for the PCV system was leaking so bad we couldn't build any positive pressure.
After capping off the port on the throttle body, we found that the flange for the SSQV is also leaking a tad, but not nearly as bad as the throttle body was.
So while I dinked around with the BOV, Heidi swapped out the TB for a spare one we had lying around.
The problem is that the new one seems to blow straight through as well. It was my understanding that there was a check valve inside that port that allowed the intake manifold to apply vaccum to the crankcase, but would not allow manifold pressure to flow the other way.
Testing both throttle bodies, it seems that there is no check valve in either, or both check valves are shot. Assuming that there is no check valve, how on earth is it supposed to work? It is a straight shot from intake manifold pressure to the accordian pipe. The TSRM says nothing about a check valve, and only mentions that you should clean the orifices with solvent, and blow them out with compressed air. I suppose it is possible that both TBs are shot. Can anyone verify if there is a check valve, and if so, is it strictly a one-way valve, or does it require 5 psi or so before it closes?
Any help with this would be greatly appreciated.
Thanks,
-Jake
Thanks,
-Jake
