Boost in Park/Neutral?
Supra5MGTE
421
Tampa, FL
if i'm sitting there in neutral and rev the engine good and hard is there supposed to be any boost? B/c I don't see the boost gauge move, stays in the -4 even when I reve the crap out of it. would it have something to do with the automatic trans switch?
OneJoeZee
Retired Post Whore
aboard the Argama
i can boost .5BAR in neutral lol
edit: oops, i see this is the 7M section >_<
well, i never made any boost in neutral with my 7M. maybe a little past zero, but not much
OneJoeZee
Retired Post Whore
aboard the Argama
the stock 1J twins just spool really easy. lol. not much to it. ive seen my car go into boost before on the highway just from a small incline. no change in throttle.
aye mate
Hiatus over.
Maryland
I can build about 4psi. More than likely your stock gauge is a little slow and doesn't read it. Try an aftermarket boost gauge.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
IJ I have visions of the movie American pie in my head... just shepherds pie instead of apple pie on the counter.
But yes you should be able to boost SOMETHING in neutral. Get a good boost gauge!
Supra5MGTE
421
Tampa, FL
Ok, so my car isn't retarded then. I kinda have the feeling the Stock gauge is slow in the head though... Anyway to put a Autometer boost gauge in the stock location? b/c having 2 boost gauges is kinda ricer.
IHI-RHC7
"The Boss"
Oregon
It's a bit of a chore retrofitting an autometer in the dash, a good alternative is utilizing an NA dash, and getting an oem voltmeter. (i'd swap the volt meter itself, not the whole assy.)
There's a good post on fitting guages in the stock location in the general section, just do a search for custom gauges.
