So i tried searching and nothing really applied to my issues...and i tried googling for a bit but that didn't go so well ether.
I installed a boost gauge to me car today and it is all over the place.
when i start the car it will remain at 0psi and only pull a vacuum while driving...no more than -10 vacuum. No i know i have a boost leak and am aware of that. under boost it will goto about 5 psi and then when i let of the gas(right off) it will drop to 0psi then jump to 5 and then slowly go back to zero
My conclusion is that my bov is messed. Now my boost leak is from cracked hoses to the BOV and from. I have a new assembly on the way...but im just wondering if it would just be the BOV not doing its job. and causing the weird issues...or i hooked my boost gauge in the wrong place.
It is hooked to he hose that goes to the bov.... It is spliced about midway in between the intake and the hard pipe that leads to the BOV. is there a better place i can hook it up?
