here are some pics of my install in the attachment part.
you cant see the lines "teed" but as I said, the arrow points to where I "teed" into the line. Also if you see where the turbo pressure unit is, you can follow the line to where it is most convinent for you. (the line connects under the unit but is very visible)
I installed the gauges in a lowtek pillar pod so I ran the wires in the space between the dashboard and the body. Had to pull the wires trough using the stiff wires of the egt lines as a guide. it was fairly easy. I have yet to tap into some line for the lights but all I have to do is remove the little cluster of switches on the left of the steering wheel where the dimmer switch is and tap into the appropriate wires. (the insturctions that came with my boost gauge and egt require a constant 12volt signal when ignition is on and a 12v source for the lights when the dash lights are on. I know that there is what I require there, I only have to find them. I havent done this yet because my car is at the shop getting a rebuilt engine put in (if you couldnt tell :biglaugh: ))
I have also done a boost gauge in my friends 87t supra and we ran the line through the gauge cluster and installed the gauge hanging down form the dashboard. (that require alot of time, patience and alot of test fitting to make sure the holes didnt go through any electronics and all the holes lined up.) For the lights, I tapped into the little cigarette lighter light.
Hope this helps. Just remember dont kink the plastic line and leave yourself extra wire incase you ever need to to anything.
