Well not sure where to start.
I can say this, newbs and guess masters need not apply.
Im running the lex 550 combo with all the fuel mods (pump, reg, etc etc).
Im not sure whats going on, but here goes:
When I go past 9 or so psi the "pull" through the RPM range is horrible. The engine and turbo make tons of go fast noises, but the car just doesn't pull.
-Boost leak?
Nope. Pressurised the boost system and no leaks.
-Dead cyl(s)?
Nope. 170 accross the board.
-Bad plugs?
Nope. All at .030 and some what clean. Installed new ones just to be safe.
-Bad BOV?
Nope. Even switched to another KNOWN working BOV and still the same result.
I really don't know where else to look. I thought possibly the TPS. So I switched to a FACTORY throttle body that I know has never been monkied with.
Now all the car does is backfire like mad, and the "pulling" issue is worse.
I also ispected the clutch and all of its components and all apears to be working correctly.
Any help on why the car is doing this and or what its doing would greatly be appreciated.
:biglaugh:
-Boost leak?
-Dead cyl(s)?
-Bad plugs?
-Bad BOV?
:biglaugh:
