boost falling off
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
so i got my mbc installed and i have it set at 9 psi for now.i notriced today that in second gear i'll get 9 psi at around 3500ish rpm but it will fall of to 5 by red line.in third it wont to it as much although i havent redlined third yet.what could be the problem?boost leak?i have a 3" elbow back exhaust, could my stock elbow be restricting me?or is it my tired wastegate?i got 5si max before i installed the mbc out of my wastegate.
actually, i just got all the parts to make a booost leak tester, i'm gonna try and finish it tonite.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
i switched this waste gate over from the blown turbo that came with the car because i didnt know if i trusted the waste gate that came with my "new" turbo.the guy blew the turbo cus he was running 14.5 psi with it.i'm guessing shitty wg too
MKIIINA
Destroyer of Turbos
Plano, TX
if you are running the stock dp and a stock turbo and have an old tired wg its a triple threat boost issue.
1 shim the wg as suggested
2. get a widemouth elbow
3. get a bigger turbo as the ct tends to run out of breath up high
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
yeah true..... with out a "turbo back" you wont get the flow out quick enough.....
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
probilly a bad wastegate shim it and see what happens....
if i do my swap in the next few weeks ill be parting out my 7m ill let u know if it turns out to be ur wastegate...
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
chances of having 2 bad wastegates is pretty slim. you most likely have a boost leak. i had this problem once when i first bought my car and had a mbc and it was a leak where the plastic elbow is it had a small crack. it could also be a bad bypass valve.
AaronsSupraMKIII
254
Athens, AL
Sorry to hijack the thread, but when I boost, It will just boost for a few seconds then goes back to vaccum. How long should it stay boosting when I accelerate? I think I have some problems...
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
it will boost as long as u are on the gas....... your turbo sounds like it may be crapping or a major boost leak or a crappy wastegate......
unless the gauge or sender unit is messed up.....
:aigo:
AaronsSupraMKIII
254
Athens, AL
:aigo:
My turbo has no shaftplay and I have a really good boost controller, I think it is my wastegate. It might be a boost leak to though. I will try and shim it when I get some time. I work 7 days a week, and its been so hot I havent felt like dooing much. I havent even messed with the other supra at all since I brought it home. I really need to get my DD running right though. lol
Its my first turbo, so I just didnt know for sure if it was supossed to boost when I am on the gas, or not, but I figured it should boost alot more than it does now.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
no i meant i havent used the other wg that came with my new used turbo caus ei didnt trust it.i just got back home visiting the gf so i didnt have time and tomorow i work all day but tues or wensday i'll check for leaks and if there are none i'll put the other wastegate on.
