Set up- BPU 7mgte
Issues- Boost will not hold or exceed 5psi
Possible Culprits- Wastegate/boost leak, ?
The Cool Story- Installed the new DM IC Kit.
-day one held boost just fine(10psi with Hallman MBC)
-day two, i ate a driveway(my car is pretty low) and broke the lower ic pipe t-bolt clamp. It still clamped the coupler with just enough force to still drive the car fine out of boost.
-day three comes and im in for the clamp replacemet! Done, i turn boost all the way off to wastegate spring pressure only, test drive comes and i see ZERO boost at WOT? hmmm. Go time again!, come to find, coupler to turbo clamp was loose, Done!, test drive #2, i get 3psi at WOT?! Go time again but this time throwing some shims on the wastegate for testing purposes and i see 5psi dropping off ~3psi.
A boost controller technically, bypasses the wastegates spring pressure correct? so meaning since i have a MBC, i can just set my boost levels where i desire without any drop off issues?
And here i stand making this thread. Im thinking its the wastgate spring/stuck open or a boost leak that im too mentally incapable to find? Any ideas or thoughts here? thanks in advance!
