Hi guys trying to keep this as brief and as informative as possible.
The issue:
Boost drop at high rpms. ~16psi down to ~11psi
...also worth mentioning it only makes 11psi max in 1st gear and 13 (also drops to 11) in 2nd. 3rd is where it will hit 16psi and then drop at around 5000+rpm.
Related Mods:
- Driftmotion 57 trim CT26 with ported wastegate (as it used to creep)
- stock wastegate actuator
- Tial 50mm bov with 10psi spring
- split-recirculating downpipe and 3” exhaust
- driftmotion intercooler kit in/out on same side
- Blitz SBC
I have performed a boost leak test and found no leaks, assuming i've done it correctly. (Pumped air into the turbo inlet and blocked of the end of the 3000 pipe?)
I've previously had the boost controller hooked up to the nipple on the compressor housing and just yesterday tried getting the vacuum source from the intake manifold instead to see if it would get it to hold boost but it does the same thing.
What may be the issue?
- Old/weak wastegate actuator
- boost leak
- BOV leaking
any help would be appreciated. cheers.
The issue:
Related Mods:
- Blitz SBC
- boost leak
- BOV leaking
