boost cut
AZN MK3
341
Now in the U.S.
when does boost cut hit?? and is there a way i could eliminate my boost cut with any devices out there like a boost cut defencer or defender whatever that thing is... if so what do you guys recommend? thanks again in advance...
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i recommend an SAFC
especially if you are planning to up the boost so you can tune it as well.
i'm on 440's with a 60-1 and i'm at -8% across the board on my SAFC and im hitting fuel cut at 16psi. so im maxing out my injectors already!
im happy cause its making awesome power, but mad because i've only had the 440's for a month and i already have to upgrade to 550's LOL
AZN MK3
341
Now in the U.S.
The Reaper;947263 said:
i recommend an SAFC
wow... dang... well i do have a afc neo already installed but not tuned... tired messing with it but dont really know what im doing so i left it alone... i get confused on how to do the air map so i didnt bother messing with it...
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
SAFC is good for tuning to around 550hp, but its not a boost cut device.
Any flavor boost cut hardware works ok. I'd honstely just reccomend a aftermarket reflashed ECU like a blitz, sard, etc with fuel,boost,speed cuts removed, as well as higher redline.
89supra
md
A SAFC wont get rid of boost cut, I'm with Ric get an ecu before standalone I ran a Mines ecu worked great
AZN MK3
341
Now in the U.S.
well i know that SAFC wont take out boost cuts. but i was just looking for something kind of cheap... just something to raise my boost cut a little bit more...
so a greddy boost cut controller would work? if so cool... and where though could i get a reflash ecu from???and whats the cost??
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
cheap and fast do not work. if you are hitting cut you need more fuel and better type of management system (safc is pretty useless isnt it?)
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
SAFC works good on top of my SARD ecu with 550's. Really good actually.
Cheap and Fast usually = you're not fast and it costed you twice as much in the long run to do it right. I wouldn't reccomend a stand alone ECU for a daily driver, find yourself a reflashed ECU and use a MAP-ECU 2 piggyback. That setup is good for 1000whp electronics wise.
Re-flashed ECU's run around $500 average.
tissimo
Stock is boring :(
Melbourne, FL
boost cut is a good thing.. when you hit it you're out of fuel. So just get a tuning device and tune your car out. Once you hit fuel cut, upgrade your fuel system
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
You can have 1000cc fuel injectors on stock twins and still hit fuel cut on a stock ECU at exactly 1 bar. :3d_frown:
tissimo
Stock is boring :(
Melbourne, FL
if you tune it with 1000cc injectors it will never hit fuel cut
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
If this system is like the MKIVs boost cut system, they you will need a BCC (reccomend the MR2 one as you can tune when it kicks in).
tlo86
Jul 24, 2005
3,914
Colorado
x2
cbutler
218
Regina, SK
i recommend an SAFC
let me know if you're getting rid of your 440's, I may be interested.
The Reaper
Jan 10, 2006
1,909
Florida
will probably be getting rid of them fairly soon for some 550's.
and when i said SAFC i meant exactly what Justin is saying......if you tune the car you can raise the fuel cut. never had any fuel cut issues with my 60-1 7M supra, and with stock twins and stock 1J ecu i was getting fuel cut at 14psi. all i did was hook up a EMB and E-01 and tuned it a bit and fuel cut was now 18psi. then i sold my EMB and E-01 and now i have the Aristo ECU and SAFC and 440's, fuel cut was hitting at 13 psi. i tuned it a bit now fuel cut was raised to 16 psi which is where my 440's are maxing out.
so to say that an SAFC is useless as a boost cut controller is retarded. boost cut being removed completely is a dumb idea as well. i'd prefer to hit it so i don't kill my motor.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Reaper, I have some 550s that I will trade for 440s, provided you pay for the shipping of both :). Milage on the 440s?
BTW MKIV 550s ~70-80k miles
AZN MK3
341
Now in the U.S.
ok i read something on SM, that you could swap out the map sensor to raise up your fuel/boost cut. and if so what map sensor should i use, or is it even recommender, again im on a stock ecu, with a neo, walbro 255lph, stock injectors, and im running 13 psi right now. just want to raise it up to exactly 15psi. also do i hit fuel cut first or boost cut??? just confused right now just dont know if im hitting boost cut or fuel cut?? thanks again...
