Im having an issue with boost creep. Boost will shoot to 6 or 7 hoover for 5-700 rpm and then climb to 12-15. Heres my setup apexi power intake, lexus afm, 550cc, nonturbo pistons .5mm over, ported stock exhaust manifold, (I think) bic 3" divorced (recirculated) dp, 3" straight pipe to an apexi n1 muffler, and a light weight flywheel.
Ive tested the wg actuator starts to move at about 5psi. Linkage moves freely pulled the down pipe off. The divider plate was slightly bent but I don't think it was enough to cause an issue. Where the dump pipe comes back into the main exhaust there is about a 1/4" or more lip all the way around where the hole in the main exhaust is smaller that the dump pipe. Not sure if this is an issue or not.
Im wondering if the nonturbo pistons and slight over bore are not part of the problem also. My plan as of now is to port the wg hole in the turbo an open up the hole where the dump pipe goes into the exhaust. Any other ideas or suggestions?
