Boost Controller
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Will This Work???
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
that would work in theory, if you had the boost controller connected to atmosphere instead of the intake manifold.
How are you expecting it to bleed off pressure that way?
the better way to do it would be to hook it up as per Joe's turbo diagram.
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Bad idea.
Good idea:
Run the two pressure lines from the turbos into the controller's input (using a tee to make the two lines into one). Then run the output line (using another tee to make one line two) to each wastegate.
annoyingrob
Boosted member
Jul 5, 2006
2,304
BlackMKIII;916351 said:
Bad idea.
Good idea:
Yeah, that's exactly what Joe's diagram was. That's exactly how I used to run my twin setup too.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Ok i hooked up the boost controller today and the car will spool up to 15psi really fast then will cut of violently and bog down the car...
What could be wrong???
It does the same thing at any setting of the boost controller....
:1zhelp:
Freshmaker
396
Oconomowoc, Wi
Sorry I didn't get to reply sooner after my first post. You second drawing looks good. Your symptoms sound like fuel cut as fstlane said. It means you arn't opening the waste gate early enough for the ECU right now.
A couple possibilities:
Left a vaccum line off/hole in the system
Boost controller hooked up backwards
Boost controller set to high
PS. Im sure fuel cut scared the shit out of you, its not a huge problem to hit it. Its a safety net the ECU has in it so that it doesn't continue to boost in a malfunction setting and blow itself up. Fix your controller and you should be golden.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Could it be because the front turbo has shorter vacuum line to the boost controller than the rear turbine???
In other words; the boost controller is near the front turbo so has less line to pass through???
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
stevenr816;921023 said:
its cause your running too much boost buddy, fuel cuts 12-14psi
so in other words lower your boost :cry:
Or get bigger injectors, walbro 255, FCD(the MR2 as its tunable) and a tune.
OneJoeZee
Retired Post Whore
aboard the Argama
If this is happening even when the controller is turned all the way down, check your tees and make sure the ID isn't too small. And make sure the routing is right.
Freshmaker
396
Oconomowoc, Wi
Line length shouldn't cause your symptoms.
I would remove the controller and run it with something straight through. If it boosts to stock pressure fine, then the problem was with your controller, if the problem is still there, fix your routing.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Oh hey i just remembered my O2 sensor has gone to sh+t... Could that be my prob???
I am going to hook the boost controller back up to remove the controller and run it with something straight through.
