Ok so, here is a question for the masses. With my next setup, I am trying to find out how much boost I could run and what power I should expect from it. Here is what I will have done. I just want to know if it will even be worth it for us.
from top to bottom
BC valves
Ferra springs and retainers
BC cams
Titan Cam Gears
JE .40 oversized pistons
Eagle H beam rods
ARP bolts and studs all around
Clevite 77 bearings all around
HKS Stopper 2mm
Master Power T70 (1.15 hot side/? cold side)
Custom Manifold
Tial wastegate
Blitz NUR Spec 3"
custom 3" IC pipes
not sure of IC yet
Walbro 255
RC 550 injectors
Aeromotive AFPR
Apexi AVC-R
possibly a MAFT-Pro
GReddy/Trust Type R bov
Aluminum drive shaft
Machine work to be done
5 angle valve job
CNC combustion area on head
Port and Polish head
Port Match to intake
Block bored 40 over
crank polished and balanced
I might have missed a few things on the list, but as I remember them I will add them. I just want to know what a safe estimate on the boost could be. High limit basically. If it is around, oh I don't know, say 20+ psi, what type of power am I looking at? I would really like to get up around 500+ if possible.
from top to bottom
BC valves
BC cams
Titan Cam Gears
Eagle H beam rods
HKS Stopper 2mm
Custom Manifold
Tial wastegate
Blitz NUR Spec 3"
custom 3" IC pipes
not sure of IC yet
Walbro 255
RC 550 injectors
Aeromotive AFPR
Apexi AVC-R
possibly a MAFT-Pro
5 angle valve job
Block bored 40 over
