boost affect on in.man. gasket?
isnms
United States of America
Oklahoma
i80.photobucket.com
What affect does boost have on the intake manifold gasket ( IMG here after )?
I found a hole in the IMG between 1&2. I took it back to the machinist who did the rebuild. Good machinist and had no problem replacing it under warranty. He asked me if I was running a lot of boost. I try to keep it at 11psi and under since it hits fuel cut at ~12 or above depending conditions. He said that the IMG was "accordioned" out.?. He said that he could see the impression where it had been seated. I haven't seen the gasket, and probably won't get to, so I don't know exactly what he was talking about.
What could cause the IMG to accordioned out?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Is he talking about boost pressure pushing the gasket out from between the two mating surfaces? Are you running stock Toyota gaskets? I didn't think this was possible, at least not with the stock gaskets, they are pretty solid...
isnms
Oklahoma
i80.photobucket.com
That is what I gather from his description. I only saw the hole between 1&2, from the outside. A smoke test revealed that and no other leaks at all.
I don't know about it being Toyota gaskets. Not sure what kit he got to do the rebuild.
