bolt in widage tray and sump baffle kit for 2jzg(t)e
just thought id let you all know what i found on ebay, have not seen these before sold anywhere. made and sold in australia.
a windage tray is a medal tray that is bolted to the main caps on the bottom of the engine that is designed to keep the engine oil from splashing up in the engine and stop the oil pump pick-up tube from sucking air instead of oil. It also stops the engine oil from foaming in the oil pan due to splashing.
and the baffle box is to reduce the movement the oil in your sump when you corner/brake/accelerate.
if you read the listings on ebay it goes into this a little... google is your friend
DISCUSS
to find search :-
SURGE PLATE/BAFFLE BOX suit Toyota Supra 2JZ-GE/GTE
SURGE PLATE/BAFFLE BOX suit Toyota 2JZ-GE/GTE RACER
WINDAGE TRAY suit Toyota 2JZGE-GTE with rear sump-SUPRA
pictures from ebay listings
dslocal
340
slo
Thanks for posting this! I am working on building my 2j right now and was planning on making something like this. Just needed one to copy, I am going to make them out of Stainless Steel, and try to incorporate a crank scraper.:naughty:
Let me know if anybody else wants one. I'll be able to beat the ebay one's price.
