blowing out plugs and ticking from valves
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi guys. I turned up my boost to mabye 9-10 lbs and i think my plugs are blowing out. I had them gapped at .028". What am i doing wrong here? Also, my head is making this ticking noise. Its not the injectors. When i put in my head one of the threads of the bolts on the cam journals had stipped so i put it in loosely. how would my car run without only one cam journal? thanks
-Steve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
bpr6eix-11. will a colder plug help? i had the plugs gapped to .028" Yes, my engine may have a cam cap loose.
-STeve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
lagged said:
say bye bye to that head.
crap, its all good tho because i have an N/A head that looks pretty damn mint and a turbo head that i got for free from a member on the forums; however, i dont know the condition of the turbo head unitl further speculation. Which head should i use? thanks
-steve
lagged
1991 1JZ
new rochelle
they are both the same so it dosnt matter.
if i were you id take out the cams from the head youre using and inspect the journals. it might still be good.
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
journals are DESTROYED lol
Oct 11, 2005
3,816
Thousand Oaks, CA
Are the bearing cap saddles scored? The journals almost always look bad because they has a soft babbit-like coating that scores easily. The saddles should be absolutely perfect though.
If you stripped one of the threads for the bearing caps then that head is done. I do not believe it is possible to helicoil due to the pressed in guide surrounding each bearing cap thread. The cam caps must be torqued no more than 14 ft-lbs as the threads are in aluminum and the bolts aren't very long.
LordLo
242
OR
Back in the day when I worked on my celica I cross threaded one of my cam bearing bolts and sheared off the head bolt completely. What I ended up doing was just rethreading and it held up fine for 3 years until I blew the headgasket on it. haha.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Get some NGK 2330's gap them to 0.28 and a new set of NGK wires call it a day. If thats does not solve your issue go down the list ..... timing, check coil packs and everything else in the ignition system.
