whats up guys, i keep blowing this fuse in my kick panel. it was a 15 i tried a 30 and it still blew. im guessing theres a short somewhere....any ideas?
Poodles;1277489 said:DON'T put a heavier fuse in there unless you want to damage the wiring or start a fire.
The rest is trial and error. What did you do last? What causes it to pop?
Poodles;1277546 said:More than likely grounded a power wire...
Poodles;1277563 said:probably the one to the radio, ashtray, or cigarette lighter...
Boosted516;1277735 said:lol i just checked my radio wiring and the green wire coming from the dash to the radio harness has the cover fried off.as far back as i can see. im guessing thats what is causing this? what should i do? lol
jdub;1277752 said:That is probably from using a 40A fuse in a 15A circuit. To be honest, that was friggin stupid. :3d_frown:
Now, you get to replace that entire wire.
jdub;1277780 said:It supplies power to a lot of different things from junction box #3 and directly from the fuse:
http://www.cygnusx1.net/supra/Library/TEWD/MK3/manual.aspx?S=Main&P=062
(and the next 2 pages)
The beauty about this is most wires are green, white/green stripe and green/white stripe. You are going to pay dearly for this one...you are very lucky you didn't start a fire.
The 1st thing you have to do is replace that wire and don't ghetto rig it. Have fun
BTW - JJ's comment can be interpreted as "the stupidity never ends". It never ceases to amaze me me either.
jdub;1277966 said:You are going to have to trace the wire along the harness visually. Taping the frayed part is not going to do any good at this point, you've burned the insulation off along the rest of the wire and you may have damaged other wires in the harness. If it touches a ground point, it will happen again or if another wire is damaged, it could happen to a different circuit. I suggest you take my advice...don't do a ghetto rig with tape.
