Blocked off water pipe?
Doward
4,245
Alachua, FL
I've got a water pipe on the back passanger side of the block, that is capped off... I looked in the online TSRM, and it doesn't show where it goes, either! Any ideas?
Doward
4,245
Alachua, FL
Here's a pic of it -
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Yellow is mostly correct. I've seen many cases of this plug becoming brittle over the years and failing, blowing all the coolant out onto the exhaust manifold, which creates a huge steam show, then the engine overheats and the head warps, causing a BHG in the process.
SO... considering that plug is about $7 from the dealer, I suggest people replace it every year. Or crimp that hardline and weld it shut.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
PS: This is a fantastic example of how to get your questions answered. Clear, concise title, high resolution photo in focus of the subject, no begging or whining... I like it. Doward, you're welcome to stick around as long as you like. :D
While ND is technically correct in that this has been covered, and recently IIRC, anyone asking questions in this manner makes it so easy that I don't mind going over it again.
What Grim said! :)
Only thing I'd change is to make the pic either a thumbnail or a bit smaller so people don't have to scroll to see it all! (800x600 is safe these days)
As the text follows the pic off screen!
Doward
4,245
Alachua, FL
ND, did a search on SF, and come up with nothing... probably not using the correct terminology.
To the rest, thanks. I try to make it as easy as possible :D
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Bahh... I enjoy the wierd mysteries with poor descriptions and teenie tiny itsy bitsy blurry pictures. More of a challenge and fun to read..:biglaugh:
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I was looking at mine today, and it doesn't have that on it.
Car's a 90 Turbo in case context clues fail you. ;)
Just thought it odd and figured I'd chime in.
