block off plate? pic inside
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
i just did an overhaul on my 7m and got to this:
does a bock off plate go here? (left circle)
jdub
Feb 10, 2006
10,730
Valley of the Sun
The one on the right is blocking the exhaust gas feed.
The one on the left doesn't matter since you don't have an EGR cooler and the exhaust gas feed is already blocked. A plate here is purely cosmetic and you'll still have an open hole on the left rear in the EGR cooler area.
A very important place to have a plate with no EGR is the rear of the upper intake manifold, below the brake booster fitting. The EGR attaches there to feed exhaust gas from the EGR valve to mix with intake air....no plate = massive boost leak.
BTW - You're going to have a heck of a time passing AZ emissions with no EGR. Tried it myself using every trick I know of...had to install an EGR to make it pass the dyno test. The only way I know of is with a full stand alone EMS tuned to pass.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
you clearly already have a blockoff plate installed on the back of the head. The only other necessary plate is on the intake manifold.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
You guys are right. :)
On a related note, I can't remember what the back of the head looks like on a JDM engine.... Do they block it off, or is the head not even provisioned for the EGR hole?
jdub
Feb 10, 2006
10,730
Valley of the Sun
It looks identical to the picture...all the heads I've seen (JDM or USDM) have the EGR holes.
JDM heads usually don't have the EGR cooler though.
