Blitz 300kph Speedo
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
How hard is it to install the 300 km/h Blitz Speedo face into a gauge cluster?? If you remove the speedo screws does it ruin the gauge cluster and how would a speedo shop calibrate it properly? Any info on speedometer face install would be great.
Geoff
Jeff Lange
Administrator
4,922
13
Sunnyvale, CA
jefflange.ca
I'm Calgary, and can help quite easily, just let me know. I've done stuff like this many times.
As far as the install goes, the speed face will have to modified slightly, and the calibration will need to be changed, but it's not a huge deal, the stock speedo should be able to adjust for the calibration, and modifying the face to fit should only take a few minutes.
Last, but not least you'll want to change the way the lights light up on the cluster, this won't be too hard either, especially if you have an airbag cluster to start with, but it's still possible without.
