Blinking O/D Light after Manual Swap
Transmission has been swapped from Auto to Manual and now the O/D light blinks constantly.
I tried searching but couldn't find anything specifically to fix my issue.
Is there an AT computer that needs to be removed?
I'm not getting a check engine light, only constant blinking OD light.
Thanks!
mikeoc1
109
Ft Benning
Is your ECU for manual or Auto? The ECU should say M/T on it? Not sure if that would be reason for blinking but the Prev owner did the swap on mine and I noticed he swapped the ECU. I ended up swapping my instrument cluster for a manual trans cluster as well.
