Let me start off by saying that I do know about the hazards of upping boost without adding more fuel.
My engine is currently being machined and the lower end assembled. The list is as follows:
Completely rebuilt head w/3 angle valve job and some mild porting
Cometic MHG (on it's way)
Wiseco pistons
eagle rods
ARP head/main studs
new pumps/gaskets/seals/bearings/etc.
Full T4 setup with tubular manifold, turbonetics 62-1 turbo, and 50mm wasgate with 10 psi spring.
New godspeed intercooler (25 x 6.5 x 3.5 w/3" inlet/outlet)
3" hard pipes
3" exhaust
K&N FIPK
That is the major stuff, no fuel mods/tuning device to speak of. My question is this: will I be safe running 10 psi until this summer when I have money/time to do my second stage (MAFT-pro, larger injectors, FPR, fuel pump, etc.)? Does anyone know what the calculations are for flow rate and boost to stay in good A/F values? Is the stock fuel cut based on boost or flow? Does anyone know the stock ct26 flow numbers so that I can estimate the flow rate per psi that would be safe?
Many many thanks in advance, just trying to plan this out before I start putting it together.
Edit: basically what stock ct26 psi does 10 psi on a turbonetics 62-1 turbo translate to? Will I need to get a smaller psi spring for now to be safe?
Wiseco pistons
eagle rods
ARP head/main studs
3" hard pipes
3" exhaust
K&N FIPK
