BIG PROBLEM!!! NEED HELP FAST!!
suprafanatic
1,607
Greenwood, IN
ok so i just got done installing my 60-1 turbo.. car has been sitting for the week while i worked on it.. i pulled the efi fuse so i could crank the engine to get the oil presure up to prime the turbo... to my suprise i turned the key and nothing, also i dont have any power like no dash lights, no radio, no dome lights,, the only thing on my car that works are the head lights :1zhelp: thought the bat. might be dead so i went and bought a new battery.. still nothing works but head lights.. so any ideas?? i'v check fuses there all good. :cry: i have to get the car running my sunday. so please please help me!!! thanks guys.
suprafanatic
1,607
Greenwood, IN
ok some to add to the stuff that works,, i have head lights, brights, cig lighter, and hazards, NOTHING ELSE!! no brake lights or anything. i really need some advice guys.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
check the wire that comes off the + of the battery not the big one the smaller one i had this same problem and that wire were it is crimped together had come undun.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
on mine there is a smaller red wire that is also hooked up to the positive and about 8 or so inch's off the battery theres a crimp connector connecting it to another wire (atleast on mine) and it had come out of the connector and it killed everything.
suprafanatic
1,607
Greenwood, IN
OK GOOD NEWS!! i found that the ALT 100A fuse box thing is blown... would that cause the problem??? and how in the world does it come out?? going to get a new one.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
iam not quite sure what your talking about... but yes any blown fuse especiall one that big could and probally is your problem. as for what cause it iam not sure because i dont know what fuse your talking about.
Mark's MKII
7MGTE
Jul 13, 2006
14
Nashville Tn.
Unbolt the fuse box from the car, take the bottom of the box off, push the 100 amp fuse through the bottom of the box and unbolt the fuse. I think it has 2 8mm bolts holding it on. Insall new one in reverse order.
suprafanatic
1,607
Greenwood, IN
ya i got it and car is running!!! and wow its awsome.. only boosted 5psi so far and its equal to like 10-12 psi on the old turbo,, cant wait to try 10 on this new turbo :) also no oil leaks or other leaks so far, all is well. luckily
shaeff
Kurt is FTMFW x2!!!!
10
Around
MDCmotorsports said:
Check your fuses, fusable link, and make sure you don't have the battery hooked up backwords.
jon already told you what it is. :)
-shaeff
