Big misfire/ cutting out problem
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
well i just got my 1J swap running in my 87 recently and i went to go drive it today to make sure it runs ok before my friend comes over to give it a lil tune on my afc. well going out of my neighborhood (1/4 mile to the gate) i can drive it just fine, no probs, can boost fine and all. but once i leave the neighborhood, in any gear i get a nasty cutting out, the car will cut out to where it does nothing even when i push the pedal to the floor. then all of a sudden itll jerk back on run for a sec, then cutout again doesnt backfire or anything when it does it. zoon and i thought it might be too much fuel for no tune, so i took out my mines ecu and 440 injectors and put in the stock ecu and injectors. still cut out after that. so i checked all the coil packs, they all are working fine. before i drive it while it idles i can rev it to redline if i want with no cutting, but when i bring it back after trying to drive it, i cant rev it while the car is sitting. so were thinking that it might be the fuel pump or the FPR (ive got a walbro 255 and a stock FPR for now) that might have taken a dump. was wondering if anyone on here might have an idea on this?
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
it turned out to be that my strainer was covered in crap, i gotta get a new strainer and get the tank cleaned.
