BIC mounts
S
Supracharged88
Guest
hey guys i got my bic mounts on but i had to take off the fuel filter and some small support bars. i was wondering if these bars need to go back on and what others have done with the fuel filter in the past?
becauseican
Vancouver
www.bicperformance.com
The intake support bars need to be removed when using the mounts, but they are not needed, I have been driving without them for years without any problems. And the fuel line block will also fit with the brackets. Which motor are you using?, supra or soarer?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
does it matter if you use a soarer or a supra 1jz when putting it into a supra body w/ your mounts?
S
Supracharged88
Guest
i am pretty sure i am using a supra motor, how do i make sure?
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
becauseican said:
The blocks are the same, and the brackets will work on either, just the oilpan/ sump is different and the fuel line block thats on the stock bracket is different.
any one with a comparison picture?
