BIC DDP and test pipe questions
Compton74
355
Long Beach
So as title states I have a BIC DDP, and just put a test pipe on my 3 inch hks exhaust ( not sure the name of it but it's the one that looks stock and is quiet). Now my question is Fuel mileage has greatly suffered after I took the cat off and put the down pipe on. Nothing else was done to the car at all, and my driving habits haven't changed at all. Could either one of these 2 items cause a fuel issue? Car is a 91 with lex/550 57trim. Thanks for the help
radiod
1,342
Abbotsford, BC
Did something happen to the O2 sensor when being pulled and put back in? Was the wiring and clips for the O2 making a good connection and not fried from hanging above a turbo/exhaust manifold with no heat shields on it? First thing I'd test with a noticeably large drop in fuel economy is the O2 sensor.
Compton74
355
Long Beach
Well when I installed my original drift motion 3 inch down pipe before the BIC DDP I noticed the plug easily fell out so I replaced it with a weather pack connector, which normally never fail but I'll check it out regardless. Thanks for the input I'll come back and let yu know what i find.
Compton74
355
Long Beach
So checked the o2 sensor and everything was fine, checked the plug and connection, and even checked codes just to make sure I wasn't missing anything, and still getting less then par mileage. Any Other things I can check?
gsxr141
1,158
10
rochester
i too am getting crappy gas mileage. while i too have a bic ddp and catless 3" exhaust, i don't think that's the problem.
Compton74
355
Long Beach
shipkiller;1747709 said:
well you have 550cc and you are not tuned
I beg to differ, the original reg reimer mod states only 550s and a lex afm. Don't think there is much tuneing capability with the stock computer. Now the only reason I'm bringing the issue up to begin with is because with the drift motion 3 inch down pipe gas mileage was fine, as soon as the cat came off and the DDP went on gas mileage went in the crapper. I can throw the cat back on but I highly highly doubt not having a cat is at fault. But then again its hard to put a downpipe at fault as well. Guess I'll have to put the DM down pipe on and see if mileage changes, if so the down pipe is at fault.
TrqMnstr
HKS Whore!!!
Oct 31, 2005
442
Los Angeles, California, United States
I bet I can tell what it is, it's a rare condition called "Lead Foot". It's a mild condition that affects most vehicle owners after installing a performance part. My diagnosis, you like the way DDP sounds so you're on the gas a little heavier than normal. That or a vac leak.
STREET90
Long Beach
Compton, (black cressida) you got me concern, about this as I also have a downpipe on its way, I barely get 200 miles on a full tank, but then again I'm running a w58 with 3.93 rear end
TrqMnstr
HKS Whore!!!
Oct 31, 2005
442
"Lead Foot" is nothing to be embarrased about. Just be up front about it before any sexual activity. Ollz!!! In all seriousness though. Fill your tank reset your trip meter and calculate your mpg. Those modifications you have should not affect mpg's that drastically. Like I said before you might want to look for some vac leaks also.
radiod
1,342
Abbotsford, BC
I'm driving with a boost leak right now and getting 16mpg ONLY IN CITY DRIVING. Full turbo back 3" with the BIC DDP and cat delete. Getting mileage that low means something else is happening. When everything is working good on my car I can get ~18mpg in city, easy 21+mpg if I do some highway driving.
radiod
1,342
Abbotsford, BC
It's my DD and I haven't been able to pressurize the intake to find it. It doesn't leak under vacuum. Everything still runs fine, just running a bit rich and cutting early/boosting low.
TrqMnstr
HKS Whore!!!
Oct 31, 2005
442
Uhh no. You have a leak. Of course you gonna get bad mileage
radiod
1,342
Abbotsford, BC
I know I'm getting bad mileage, I'm saying that. I'm saying I'm getting bad mileage and they're getting significantly worse, so something else is wrong on their cars. Never said my mileage was good, thus the...when everything is working good on my car I can get ~18mpg in city, easy 21+mpg if I do some highway driving.
Compton74
355
Long Beach
Mike your only getting 200 a tank? There's something wrong then man. I get at least 300 a tank
