Recently began having problems with my '89 T. Here is what is happening;
Very distinct spark miss at idle when warm
Loss of coolant through overflow (1 gallon / wk)
I am concerned that this may be a problem with the head gasket, but I do not have any oil in the coolant and it seems to run fine. I did a compression check at operating temperature and found;
Cylinder 1 - 158 psi
Cylinder 2 - 161 psi
Cylinder 3 - 160 psi
Cylinder 4 - 161 psi
Cylinder 5 - 158 psi
cylinder 6 - 149 psi
I believe that +/- 10 psi between cylinders is within spec, but I am not 100% on that. If anyone has had a similar experiance, or can offer some new insight to this problem it would be greatly appreciated.
