BHG? Running To Rich?
got_rice_?
12
Swift Current
Please somone help me, here is the problem the day i bought my car i noticed after driving it for long periods of time it will smoke during shutting down ( turbo timer) i never really thought to much of it cause i here ct12's are a little smokey also it was minamal smoke, now yesterday i got my cat removed and now it is smoking non stop, after a few min of warming up it smokes and smokes and smokes, its a whiteish Gray smoke, doesent burn any oil or go threw any anti freeze and never has over heated. the exhaust smells like gas but how could gas cause whiteish gray smoke, the previous owner installed a hks fcon vpro ecu and tuned it for the car when it was bone stock, since then it got blitz intake, 2jz crank pully, 3" turbo back exhaust and a 255 walbro fuel pump. the car is still sitting at stock boost and i was wondering if this fuel pump could be causing me all of this smoke since its dumping to much fuel in?
thanks for all the help guys. Also i checked my oil for anti freeze and nothing, but it does have a sent of gas to it.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
compression test? BHG tester for your piece of mind they work pretty good.
is it stock twins>?
Sam
251
Saskatchewan
My car (which is the exact same Supra as yours) does that to some extent. It puffs that grey smoke, only sometimes for some reason, during the initial start up. It's very strange. It's done that ever since I brought it over from Japan.
Unlike yours, my car burns clean while running. It's a mystery...
tlo86
Jul 24, 2005
3,914
Colorado
valve stem seals.
got_rice_?
12
Swift Current
is it stock twins>?
I will be getting a compression test here next paycheck hopefully, i went to the shop and asked about a bhg today and they really dont think it is becuase of the smell of the exhaust, and yes it is just stock twins on it.
Pharnhyte
30
Philly burbs
I doubt its a BHG. Also a compression test would not likely be a good test to see if you have one; also for the time being take a look at your oil, is it milky in color? If not your probably fine.
Pharnhyte
30
Philly burbs
Oil in your piping is quite natural for a turbo car. You have 2 of those turbo thingy's.
Your factory twins are starting to go. Mine do it to, search for symptoms of bad turbo's or something along those lines. I would keep driving, and save for some kind of single upgrade.
