ok, so im pretty much out of ideas, here is what has happened up to this point...
i have a 89 7m-ge. i blew the HG and it sat for about a year and a half. Finally got the time to fix it.
After putting it all together, i turn the key and....nothing. There is a click coming from the ECU down by the passenger side door, but thats it. So i assume the stock alarm system is cutting the power from getting to the starter. I tried EVERYTHING i could find online to reset the system, twice. finally got sick of dealing with it and just went up under the steering column and took it out. The security light on the dash no longer comes on, however nothing has changed. still just a single loud click from the ECU. Any ideas why?!?!?!
Secondly, we tried running a wire from the battery directly to the starter. She turns over, but wont start. She makes smoke, i know im getting fuel and spark. Its weird though, it will turn over and almost start, and then bog down. The only thing i can think of that we didnt do correctly is, we took the distributor out before we were supposed to. could this prevent it from starting? how would i correct this/check this?
random stuff, i have a new battery, spark plugs, wires. head the head milled. just used a composite gasket since i wasnt going to resurface the block and its not going to be boosted. torqued to 85 ft/lbs.
So my two big questions are, why isnt the starter getting power? and why wont it start when i bump the started from the battery? could the wire we are using be too small and not getting enough power to the starter? Any help would be appreciated. i dont know where to go from here!!
