OK, im sure the head is cracked now.. but i just did the HG and it was throwing out white smoke had a bunch load of pressure in the cooling system, surged after i turned it off and had to refill the antifreeze a lot. Now! after driving it about 4 time its gone! I never have to put Antifreeze in it now and the heater is always on:evil2:.
The old HG was only slightly bent in the far back water channel on cyl 6 because the numb nut before seized up 11 of the 14 studs, i used stock HG and copper spray, and put the bolts down to 70lbs with 4 passes. I tapped and dyed then ran out the oil i used to tap and dye with the studs to get out as much oil as i could.
1) should i do one more pass now that the car has no BHG and crack it some more (im guessing its cracked, i used uv dye and saw no cracks)
2) just save my time and energy to rebuild the hole thing later with a MHG, and ride this out
