D
drumminforev
Guest
Which is best and why. I havent found any real answers. Also why would anyone choose a headgasket from a company that doesnt get thieir shit right and makes us grind a rivet off?
s383mmber1 said:NO. i would not buy from that company.
This is an extremly broad question! All relative to your power goals.
If you going for say around 300-400 horses, and want a more forgiving head gasket, get a cometic. Even though cometics are known to hold much much more!
The HKS/Greddy head gaskets require a very very level and milled block and head and are much less forgiving. But if your really building up the engine, and are resurfacing the block and head, you may want to think about hks stopper or such.
Stocker is a no no though.
bigaaron said:There is something about a retorque on ARP studs with a mhg that I don't like.
#1 ARP studs don't stretch like stock, and a mhg doesn't squish like a stock hg, so a retorque should not be needed.
#2 when you use a torque wrench to tighten a fastener, it takes more then the rated torque to get the fastener to start to turn. So if you have it torqued to 80ft/lbs, you might have to get to 85ft/lbs+ before it starts to tighten more. The way around that would be to loosen all of them first, then retorque, but I don't think that would be wise at all.
bigaaron said:If you do the torque procedure correctly, and go in 4 or 5 steps up to 80ft/lbs, I really don't think a retorque is needed, and ARP says it's not needed. :dunno:
