Best flywheel?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Whats a good flywheel, I used the search but came up with a million results.
So far Ive been looking at the Fidanza since I havent heard anything bad about it and the RPS CYN-R-G flywheel.
IHI-RHC7
"The Boss"
Oregon
I've used the RPS segmented flywheel. It is a great product and you can have the friction plates replaced, which is not an option for the fidanza.
Fidanza makes a decent product, but they had trouble getting the bolt pattern right for a while...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
IHI-RHC7 said:
Wow, Good find, Jake.
Why thank you Jake... :icon_razz
if you are using a REALLY aggresive clutch, like the feramic *sp* from HPF, you can use this fly wheel with it...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
I had the weights, but I dunno where they went... I know they're alot lighter than stock... I was thinking about going with one, I might still... Its just not on the top of the list of things to get yet, lol...
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
JUN one is not for 7m, I verrified with hpf that it was for the 1jz. Unless you know something I don't IJ, which seems possible...
eric
shaeff
Kurt is FTMFW x2!!!!
11
Around
the friction surface on my fidanza is replaceable. perhaps they changed it?
HPF website said:
Fidanza Starting At $338.91
Fidanza Toyota Supra Flywheels Fidanza aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1050 steel. The plates are milled to meet Fidanza'a high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners. T Toyota Supra NA 3.0L (7M-GE) + 1 more variation for the Supra
http://www.horsepowerfreaks.com/performanceparts/Toyota/Supra_86-92/Clutches-Flywheels/Flywheels
and:
HPF website said:
Fidanza Flywheel Inserts Starting At $47.81
Fidanza Toyota Supra Flywheel Inserts Fidanza aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1050 steel. The plates are milled to meet Fidanza'a high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners. T Toyota Supra 3.0L, 7M-GTE, Turbo + 1 more variation for the Supra
http://www.horsepowerfreaks.com/per...pra_86-92/Clutches-Flywheels/Flywheel_Inserts
-shaeff
Dec 3, 2003
6,653
Canada
eric
Correction JUN can be used for the 7M Ron had it in his car last year. Since he has gone a JEEZ series engine, I can't remember what he is using.
Duane
Maybe Ron could chime in later
