Hey has anyonefound an easy way to remove or reattach the bolts at the top of the bell housing on thetranny going into the block. Im putting in a jdm 7mgte in my 88t
With the trans x-member not bolted to the body and the trans supported by a jack use a 3 foot extension to go over the top of the trans and get to the bolts. You'll probably need to have the fan off or radiator out, and also the engine mounts loose.
What he said. Before I figured out that you can reach them easily this why, I took me about 9-10 hours to get the top two bolts out. Putting them back in using several extensions took me about 5 minutes. I learn the hard way, i guess. :biglaugh:
